Upgrade Laravel Aimeos from 2021.10 to 2024.10
krzysiekp
Post by krzysiekp » 23 Jan 2025, 18:39
How to upgrade from low version 2021.10 to high version 2024.10 ? Can you describe step by step how to do it so that I don't carry out unnecessary commands etc. ?
Re: Upgrade Laravel Aimeos from 2021.10 to 2024.10
Post by aimeos » 24 Jan 2025, 13:23
The upgrade process is described here: https://aimeos.org/docs/latest/laravel/setup/#process
Also, you have to upgrade your own code and you have to look at the changelog to check where your code needs to be adapted:
- https://aimeos.org/docs/latest/changelog/2022.x/
- https://aimeos.org/docs/latest/changelog/2023.x/
- https://aimeos.org/docs/latest/changelog/2024.x/
